Well, my upper motor mounts are shot so I pulled the powerhead off to replace them. In doing so, I dropped a washer from the motor mount and also a "sleeve" type thing from the top of the driveshaft down into the lower unit from above (exhaust tube came off with powerhead).
So...since i have to pull the lower unit off, I plan on replacing the water pump impellar, but what else should i replace while I have it off? I'd like to do it all at the same time. But, I don't know what "all" is.
Suggestions?
Suggestions?
