sanjivmodi
- Oct 9, 2007
- 1
I thought I had a bad fresh water pump but it does make noise when connected to the battery outside of the boat. I checked the other ends of butt connectors with voltage meter, which connect to the wires on the pump, no current on them. I tried to trace the wires but they are in a coiled housing going to the back wall of the engine compartment, I can not figure out where do they go from there. Someone said the pressure switch may be a problem. Is the switch at the helm which says galley pump, how do I get to it? How do I trace the wires further from back wall of the engine compartment? The wiring diagram in the manual is not very helpful. Any help is appreciated.
Thank you.
Sanjiv
Thank you.
Sanjiv
