One other thing. Before making this thread I searched this site to see if anyone else has had this problem. Someone with a 77' 175hp Evinrude had a similar problem (
http://forums.iboats.com/showthread....ift+rod+height). Someone suggests that the "shift rod height measurement" may have been changed or the shift cables were not properly adjusted. Here is a description of how I dismantled and re-mantled the linkage to remove the LU.
Dismantle
1. Shift into reverse
2. Removed cable from shift lever by pushing spring-loaded screw and turning
3. Removed access window panels on side of exhaust housing
4. Removed screw from shift rod connector
Re-mantle
1. Reposition LU and insert shift rod into connector and replace screw
2. Reconnect shift cable to shift level
3. Replace access window panels
Would the shift linkage need to be readjusted after this?
