Re: Mariner 4HP Impeller changing
Once you remove the two bolts holding the leg on you remove the rubber grommet and loosen up the bolt holding the upper and lower shift rods together. The reason you see the "buy a service manual" all over the net is because you need to buy a service manual if you are going to be working on your own engine. A visual guide is priceless and you are asking for trouble by not investing in one.
__________________
Elvin
My answers are like Zen...It may not be the answer you want, but it is generally the answer you need.
My Three Rules:
1) Look in your service manual first.
2) Have basic mechanical skill.
3) If you are confused, take your engine into a dealer.
