john from md
- Apr 13, 2008
- 2,184
Strange question but I have to ask.
I have an '85 Bayliner Capri with an 85hp Force engine on it. It has never overheated when it was stock or when I used a Dole Fin. I decided to get Smart Tabs and mounted them as per instructions. They were set in the middle hole and are 40lb gas struts.
Today was the first time I got to put the boat through its paces as my trailer died and I just bought a new one. First off, the boat and engine are in excellent condition and, prior to this, I would get 40 mph at 5200 RPM. Today, I was only able to get 36.6 and, if left wide open, I got an overheat. If I throttle back it would stop. The other thing I noticed was that the boat seemed to have more hull in the water. I tried several engine trim positions but there was no change. I also noticed that, at high speed, the water level was even with the cav plate. Is this normal?
My next plan is to adjust the smart tabs to the lightest setting and try it. I won't be able to test it until next friday though.
Thanks in advance for any assistance.
John
I looked in the back of
John
