S1nglefather
- Jul 5, 2008
- 4
Thanks
Oil is TCW3 and get an owners manual ... BRP website has downloads.
Will it shutdown before overheating ... No, but you should get a hot horn alert and continued running may stop it permanently. The owners manual will fill you. I would get that pronto.
If it were my motor, I would pump out the reservoir and put the correct oil in it. 4 cycle oil is not designed to be burned and the results are unpredictable.
If you don't have a temperature gauge, run the motor, for at least 15 minutes, stop it, remove the powerhead cover. You should be able to touch the cylinder heads w/o getting burned (should be ~ 140? F ... warm but not hot enough to burn). If the motor passes that test, it's not running too hot. Just be a little cautious, BC it may be hot.
