What speeds are you gettin in your Zodiac? I need help with prop selection.
Hi Guys,
This is a two-part question.
#1
I am curious what kind of speeds people are getting in 15ft Zodiacs with ~50HP motors.
#2
I have randomly tried a few props on my setup and some are better than others.
The boat:
1982 Zodiac 15ft Inflateable.
Weight: 200lbs
Bottom: Firm (NOT the hard fiberglass, but with removeable aluminum tiles that cover the inflateable keel)
The engine:
50HP 4cyl 2-stroke Mercury (1985-ish) Long Shaft with very recent total rebuild - all new gaskets, bores, rings and bearings.
Weight: 180lbs.
Has a dolphin sport fin.
Gross weight
(Me, passanger, gear, boat, engine, & fuel tank): 600lbs
It was my understanding when I got this boat that with a 50HP it should fly. My most recent trip (salt water ~60 degrees) got me to 20mph with a bit of a tailwind. I was expecting closer to 30-40 and my buddie's nearly identical boat does 24 with a 30HP Tohatsu.
The shop is assuring me that the engine is tip-top and running properly - it certainly drinks enough gas!! It does sound OK to me and has strong compression... I think the key lies in the prop diameter and pitch...
My current prop measures about 7-8" in Diameter and says A40 16P on it. I have no idea what my max RPM should be...
Could I find this information in the motor's shop manual? My local West Marine had one...
