Thanks in advance for any help. I have the above motor on a 1988 Tracker Pro-17, and recently had a problem with no voltage to key ignition after taking shifter and key switch housing off to lube it up, and found I had blown the 20 amp fuse under the motor cowl. Replaced that, and key-started the motor with garden hose & flusher on it, it ran for about 3 seconds and then died. Can run the starter with key OK now (so fuse didn't blow again), but seem to be getting no ignition. I took the cover back off the shifter control and found the black w purple stripe (looks like faded purple to me) wire had pulled loose from the end connector so the bare wire was loose and may have contacted one of the other wire connection posts perhaps. It's the wire that connects with the red kill switch wire to the M post on the back of the switch (the M post is for "Magneto" as I understand it). I put a new connector end on the black/purple wire, reinstalled it on the M post, but still can't start the enging although the starter will run by turning key to start.
Did I maybe blow the coil???? Or what else might have happened?
Any help greatly appreciated.
