tunatuggers
- Jul 4, 2008
- 2
1990 sea swirl striper with a 4.3 liter FWC v6 and a omc cobra outdrive,ok lets start this off from what all i know that has happen, this winter we found alot of water in the oil...... after changing the oil we have run this engine hooked to a hose alot but have not found any more water in the oil. we took it out last weekend and it ran ok but on our return in from a bottom fishing trip we had a overheat that actually made the moter sputter and die..... after it cooled off a bit it would run at low rpms without overheating (enough to get us back to the dock and on the trailer. ) we found impeller worn and impeller case had gotton hott. these parts was all replaced. once again we took her for a cruise down the bay,, idles ok low rpms are good and pour the fuel to her and i can not build rpm enough to even get her on the pad. on a running look at motor we find alot of blow by coming from both valve covers and no power ....... worn rings? heads? help?
