baylinerbill
- Apr 28, 2008
- 22
Ok, so the boat is running great after the new engine install
Today i was fixing a little throttle linkage issue and set idle to 700 rpm and now the throttle returns the engine to that. I had the timing light right there so i threw it on to look to make sure it was set at 8 BTDC. Well it was but every 10-15 sec it would jump around. I thought I had a thunderbolt 4 ignition, but what is the way to tell if you have a thunderbolt 5?
1997 merc 4.3lx Gen+ Serial 0K026503
Alpha one gen2 outdrive
(No Knock sensor behind the module)
I searched around and can't find anything more than 5 may have a knock sensor.
thanks all
thanks all
