I have a 57 Evinrude Big Twin 35hp with lower unit in the shop awaiting a NOS clutch dog. In the meantime, I installed the lower unit from a 56 Evinrude Lark 30hp because it appears an exact match to the Big Twin lower unit. Took the boat to the lake today and got the Big Twin tuned on the water, adjusted the control cable for the shifter and generally had a good time.
The boat is an early 60's Texas Maid 15 ft. ski boat with twin outboards (not matched); a Johnson FD-11 18 hp on the starboard side and the Big Twin on the port side. The motors are about 15-17 inches apart on the transom.
This appears a good combination, but I still had a shifting problem with the Big Twin with the Lark lower unit. It goes into gear and runs out nicely until a few minutes after attaining WOT...then it jumps out of gear. Now I haven't looked inside the Lark lower unit, so its clutch dog may be as gnarly as the Big Twin lower unit in the shop. Just wondering...any chance there is excessive slop in the shift mechanism up top? How would I check that?
Want to make sure the Big Twin is shifting well while I have its lower unit in to replace the clutch dog. When it jumps out of gear, I can throttle back, shift into N, then into F and it sometimes re-engages...but sometimes not. Even when it's in gear, the Big Twin doesn't seem to be pulling/pushing its weight as well as the smaller Johnson...which is a real champ. Both these outboards have been converted from short shaft to long shaft due to the boat's deeper transom. Any educated guesses on whether I have the outboards spaced too close...could the smaller Johnson be robbing water from the Big Twin's prop/gear case?
Sorry for the long post, never run twin outboards before so this is all trial and error.
It's a sweet combination though, they make a nice hum at speed and the old Texas Maid corners nicely. I was making 20 mph according to the old worn speedo with both outboards trimmed all the way in, and 25 mph with them trimmed one notch out. Turned a few heads, even from the Jet Ski/Flea crowd. Thanks in advance for any input.
