birdseye418
- Jul 3, 2008
- 22
while running the boat the primer ball will suck flat on any speed past idle, not just empty out but suck completly flat
i removed the check valve and it works fine, cleaned the fuel filter on the motor and replaced the fuel water seperator befor finding the bad gas
1st when i have removed all the gas i can from the in hull 30 gallon tank, how do i further clean it befor adding new fuel?
2nd. what would make the primer ball suck flat when the check valve is working and the tank vent is not clogged?
thanks
Jason
thanks
Jason
