Hi, i just recently got my first ever outboard motor. its a johnson QD-14A. when i bought it i replaced some leaking gas lines inside the power head took it out and ran out the 1/4 tank of gas the guy left in it for me and it ran great, and pumped water fine. Well the next time i took it out i ran it for a while longer. i was able to go WOT for about ten minutes and then it stalled. started it up, and it ran for 5 min, then stalled, and it progressively got shorter on the time it would run. So i took it home and went out the next day, same thing, except this time it ran for almost an hour before it started stalling.
here is what i think my problem is, on the quick connect for the pressurized tank the air line leaks, and you can hear it very loudly. it leaks when disconnected and connected. could this leak be causing me to loose pressure in the tank and stall out?
im really confused, about why it stalls. if i prime it (tank and engine) it will start right up, yet eventually die.
