shallow hull
- Jun 1, 2003
- 27
I have a 85 Mercruiser 4.3L with a Mercruiser outdrive. Boat has been sitting for a year+ with the unit all the way up.
Just tried lowering it. The trim motor whines, but nothing happens. I guess it is all the way up because it doesn't do anything when I tried going up with the switch.
Motor reservoir is full of ATF. I tried turning the wheel all the way to both sides, and shaking the unit to attempt to loosen it up. The motor still just whines.
Any ideas on what to try next, and then after that?
Thanks!!!!
Thanks!!!!
