Hi I have a 70 horse Johnson that when put in gear at Idle speed and just above idle runs just terrible stalling and hesitating if you get higher than that its fine or if in neutral runs ok also. I have replaced needle and seats in the carbs set float levels checked ignition timming and just pulled cranks seals and looked at them still at a loss of things to do any ideas ? Thanks
