Thermostat housing .
tigerhack
If the check balls have been removed from a thermostat housing what would be the result ,and come someone tell the purose of them.
f_inscreenname
Re: Thermostat housing .
It will allow the water to flow to the manifolds to easy and not to the water pump and through the motor like it should.
Ayuh,.....
The motor will Overheat at lower rpms....
