1959 water or air cooled
bosstech13
i have a 1959 evinrude v4s11 and i was wondering if i can run it out of water or will it over heat none of the guages are attached yet. mabye a garbage can of water?
R.Johnson
Re: 1959 water or air cooled
You can run it in a barrel, just don't run it dry out of the water, it will make short work of the impellor
Chris1956
Boss, Put in into a large garbage can and fill it up to the brim. Keep the hose running into the can as water will be spilled. Be careful if you put it into gear.
BTW - That motor never had any gauges, except perhaps a ammeter and maybe a tach. You only really need a fuel gauge with that fat fifty!
R.Johnson
I was thinking that engine had a hot light by then, it did not.
