  #1
Old July 27th, 2008, 07:23 PM
reelslow reelslow is offline
Default 60 HP Evinrude Controls forward, no throttle.....??
Alright, I'm new to this forum posting thing, so go easy on me. Just Bought an '82 Evinrude 60 HP..takes forever to get it started and once running, can't keep it idling. If you can get it in gear and go before it dies, it runs fine, but you can't get full throttle out of it, only about 1/4 throttle. Took off the cowling and was able to get full throttle manually, so I know it's not motor related. Possibly the cables are stretched or not adjusted properly....???? ANY help would be greatly appreciated
  #2
Old July 27th, 2008, 09:31 PM
F_R F_R is offline
Default Re: 60 HP Evinrude Controls forward, no throttle.....??
Well, you got me thinking....how are you trying to get full throttle, with the big lever on thr remote control, or the little throttle start/warm-up lever? You are not supposed to be able to get full throttle with the warm-up lever.
If I'm guessing right, adjust the idle speed to where it will keep running at slow idle in forward gear. Slight adjustment may then be needed on the cable to match it.
Mostly, do you have an experienced boater friend to take for a ride with you and explain how stuff works? Do you even know it has a choke? (primer actually, but let's not be picky)
  #3
Old July 28th, 2008, 07:03 PM
Not getting full throttle from the forward, or reverse controls. My high idle lever is broken, having to manually high idle at the boat ramp.
  #4
Old July 28th, 2008, 07:07 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
you have something wrong in the control, in forward the control should go 90 degrees from neutral. a broken pin, or bushing. you will not get full throttle in reverse. reverse is not a brake, it is slow maneuvering.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old July 28th, 2008, 07:19 PM
The controls are moving freely, with good resistance and are at 90 degrees in forward. I understand that I won't get wide open throttle in reverse, but i should get more than I'm getting, very little in either gear. Maybe I'll start by taking the control box apart and go from there, thanks for your input
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
40 Evinrude throttle adjustment with controls wheresthefish Johnson & Evinrude Outboards 2 February 17th, 2008 09:32 AM
1988 60 HP Evinrude “pulsating” at above ˝ throttle MiloKnezevic Johnson & Evinrude Outboards 1 August 23rd, 2007 04:15 AM
92' 60 HP Evinrude Dies on Shifting Forward jsmith48 Johnson & Evinrude Outboards 1 June 2nd, 2007 08:43 PM
84 Evinrude 140 VRO gear/throttle controls?? ltd3tommyd Johnson & Evinrude Outboards 1 March 24th, 2003 02:13 AM
Throttle/Shift Controls for 1968 Johnson 55 hp dtucker Johnson & Evinrude Outboards 4 December 13th, 2002 02:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
