I am trying to add a GPS unit and my fuse panel is full. What is the proper way to add another accessory in this situation? The GPS has it's own in-line fuse. Thanks in advance for the help.
you can biggy back on to something that is not used much, with the proper amperage. to do it right you add anothe fuse block. using one of the existing fuses to feed the block, and transfer what was on that place to the new block, and the GPS.
