  #1
Old July 27th, 2008, 03:47 PM
draglink draglink is offline
Default Calling RODBOLT! Need help Yamaha oil alarm
Hey Rodbolt, I have found a lot of info that you have posted on this subject but not specific to my issue. I have a pair of early 90's(1991 in think) 130 Yamahas. The oil injection system was removed some time ago by a previous owner. Well this summer I have been getting alarm and RPM reduction I assume from an oil issue(Water temps are fine and I have replaced sensors). This is on the port motor. The problem is intermitten. The wiring on the Tachs have been altered so that they read full oil (the arrow is over the full oil symbol).
The problem had gotten so bad about three weeks ago that i could not use the boat. I started tracing wires from the old oil plugs still on the motor and found the only one that went to the computer(black box on back of motor with coils) was a yellow wire. I figured this was the wire that sent signal to the computer to shut down. Cut and capped the wire up by computer and the problem was gone.......until yesterday I got it twice. DAMN! As soon as I bring RPMs back down the alarm goes out I can bring motor up to speed again.
The plug on tank side of motor has the following wires - blue, black, brown,yellow, green/red, yellow/red, green/black.
Two plugs on the other side of motor has the following wires:
BLACK PLUG- brown, blue, red/black and black
GREEN PLUG - yellow, yellow/red, green/black. green/red
The two harnesses that go into the computer on back of the motor have the following wires-
Bigger harness- brown, black, yellow(the one I cut), pink, white, green, grey/black, blue/red
Smaller harness that comes from other side black box into the back computer - white/green, white/black, white/red, and white/ yellow
Do you have any ideas what could be causing this? I'm at a loss now. Thought I had the problem solved!! I had a inboard Mako for years....could just about rebuild that old 351 Ford with my eyes shut. I'm new to outboards dont have any experience with them! Thanks for your time.... I'll take any ideas or suggestions you have!! Mike
  #2
Old July 28th, 2008, 09:36 AM
rodbolt rodbolt is offline
Default Re: Calling RODBOLT! Need help Yamaha oil alarm
first is to quit whacking wires.
just put the cutters down
either the red wire from the engine tank has shorted or the switch is acitvating.
unplug the engine tank,on the engine side of the harness jump the white to black, this will command the pump to stay off.
you can also remove the oil contol mudule completely. that old system can get flakey and if the module is failing it can tell the CDI to go into RPM reduction.
if I get a chance Ill try to refresh my memory on the antiques, however I have a dentist appt today so it may be a bit.
  #3
Old July 28th, 2008, 12:01 PM
Ha ha ha!! Step away from the cutters!! I'm at a loss and really thought I had it. The tank has long been gone. All I have left are the plugs. The plug on the tank side of the motor has no red wire. I assume that it is the old oil tank plug. It has blue, black, green/red, yellow/red, green/black, brown and yellow. Now here is something that I forgot to add. I removed what i was told is the oil control module earlier this summer when I first got the alarm. It is a black box about 3"x4" with two sets of wires(yellow, black, brown, pink). If this has been removed can I still get an oil alarm and RPM drop? If not what direction should I look? Thanks for your help on this! I really do appreciate it. Hey and good luck at the dentist.....Your dentist isnt Jimmy Woodson by chance? I believe his office is in Manteo. I went to school with him and his sister. Mike
  #4
Old July 28th, 2008, 11:05 PM
Hey Rodbolt I have been assuming this is an oil alarm, could it be a temp alarm? I have had the temp sensors unplugged and still got the alarm so I figured it was oil alarm. Is there somewhere else I could be getting overheat alarm from? I have water temp guages that show cool and you can lay your hand on the heads after running so its not running hot. Just thinking out loud...thanks, Mike
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
RODBOLT!!!!! I NEED YOUR HELP 1999 4 STROKE YAMAHA 80hp superdave1953 Yamaha & Suzuki Outboards 8 January 27th, 2009 08:49 PM
CALLING RODBOLT.....Suzuki 150SS help. TexSkeeter150 Yamaha & Suzuki Outboards 2 May 13th, 2006 10:31 AM
Yamaha Oil Buzzer (Round 2) Rodbolt igofishn Yamaha & Suzuki Outboards 8 May 29th, 2005 06:52 PM
Calling Mr. Rodbolt a.d.mobile Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 May 24th, 2005 06:08 PM
Calling Rodbolt! Mark42 Non-Repair Outboard Discussions 0 February 9th, 2005 04:39 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
