My son bought a first project boat - 1981 Tuffy Marauder fibergalss shallow V with a good 1991 40 HP oil injected Mercury 4 cyl.
The Tuffy has a floor too soft to secure pedestal seats.
Removed carpet - the floor is 43 x 149 inches bewteen the side compartments - it abutts the side compartments but does not go under them. Floor is 1/2 or 5/8 chipboard glassed over (one Matt and resin) to connect to side compartments. everything is bone - dry. No mildew either.
There are two stringers that run fore - aft about 18- 20 inches apart. The floor is 6 -8 inch above keel and even with hull at sides, and has a slight 1 -2 inche rise for last 3 feet towards casting platform.
My brother-in -law (40 yrs carpentry, drywall, construction) says leave old floor (since glassed in) and put 2 layers 1/2 inch exterior plywood . ie. 3 pcs - 4 x 8 ft sheets and run whole sheet (trimmed to width ) from back, continue with 4 ft to front below platform, then reverse for second sheet, and half sheet so seams are offset. he would bond flooring to old and staple to stringers , then reglass in flooring at top to sides of compartments to make water proof.
Is this a good approach? and is 2 layers of 1/2 inch overkill, (3/8 better) the layering is because he said we couldn't bend 3/4 " or 1 " plywood towards front.
