  #1
Old July 26th, 2008, 02:32 PM
59lido 59lido is offline
Default 1957 evinrude 18 hp flywheel nut torque specs
Hi guys,
I need the torque specs for the flywheel nut for a 1957 18 hp evinrude electric start. Thanks
  #2
Old July 26th, 2008, 03:37 PM
jbjennings's Avatar
jbjennings jbjennings is offline
Default Re: 1957 evinrude 18 hp flywheel nut torque specs
40-45lbs. on the flywheel nut. NICE MOTOR!!!!!!
I'm jealous of the e-start...
JBJ
  #3
Old July 26th, 2008, 06:48 PM
Thanks, i bought the motor and two line tank for $120. It was alittle bit more than I wanted to spend on it but when I got it home and cleaned the dust off it was like brand new under the cover. It was seized up but I shot some 2 cycle oil in the cylinders and let it sit for a few hours and it freed right up. It was not firing so I replaced the coils,points,and condensors. I'm going to try and start it before I rebuild the carb. I've never done that before. I'm sure I can work my way through it. I would not be doing what I'm doing without the help I've got from you guys. I thank you for help no matter how stupid some of my questions were. Again thanks.
  #4
Old July 27th, 2008, 12:16 AM
jbjennings's Avatar
Thumbs up Re: 1957 evinrude 18 hp flywheel nut torque specs
I was in the same shape as you were not long ago. Those '57 carbs are the easiest and most reliable carbs I've worked on. I LOVE 'em. You won't have any problem with them, just get a new carb kit with a new plastic float---not a cork one, and you're in business. Don't forget a new impeller/water pump kit before you crank it up unless you at least look at the impeller and be sure the blades are nice and flexible. You're going to absolutely love that motor and be astounded at how smooth those old dudes will run when properly tuned. If it has enough compression, it will crank no later than 2 pulls no matter what the temp. is outside. That was an AWESOME price, by the way!
Good luck,
JBJ
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
64 28 hp evinrude flywheel nut torque crash Jason Johnson & Evinrude Outboards 4 July 3rd, 2008 07:04 PM
1969 7.5 hp Flywheel nut torque wbeaton Mercury & Mariner Outboards 2 April 18th, 2007 08:06 AM
Flywheel Torque for 64 Evinrude 18 HP model 18402 topjmmi Johnson & Evinrude Outboards 2 December 18th, 2006 11:29 PM
1960 18 hp Evinrude flywheel nut torque spec. Arisaka Johnson & Evinrude Outboards 2 July 21st, 2006 04:57 PM
'86 Evinrude 70HP VRO - Torque Specs/Flyweel Nut Size bshellrude Johnson & Evinrude Outboards 0 July 28th, 2004 02:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
