  #1
Old July 25th, 2008, 06:14 PM
tawakoni tawakoni is offline
Default 2008 Evinrude 90 HP E-TEC Trim Gauge Wiring
Need help in wiring the trim gauge on my 90 HP 2008 E-Tec. What is the color code for the wires coming from the sending unit to the gauge?
I have been told the o/b already has the sending unit factory installed on it and I just have to connect the wires under the dash to the gauge..I think the wires I need come from the throttle control. A small bundle appear to come from the tilt switch on the throttle. I do not want to cut into any wiring until I am sure of which bundle to cut into and what color wires I am looking for..
I have posted this question yesterday also and got 1 reply but when I tried to find yesterdays posting, could not. That is why I am posting again..My first time here so don't know all the ropes yet..
Sonny
  #2
Old July 26th, 2008, 09:21 PM
Default Re: 2008 Evinrude 90 HP E-TEC Trim Gauge Wiring
Sonny
WOW: Everyone out there ought to be Evinrude E-TEC mechanics as they do not know the answer either???? I do not think that Evinrude mechanics are required to attend refresher school every year like Mercury mechanics are...TOOOOO BAD
  #3
Old July 26th, 2008, 09:46 PM
clanton clanton is offline
look for harness with black wire= ground, purple=hot, white/brown stripe= sender, and maby blue from nav light switch for gauge light. You should not have to cut into the harness, wires should be there, unless engine and controls rigged by unskill person.
  #4
Old July 27th, 2008, 09:27 AM
Thanks for the information...I do believe that I recall seeing those color coded wires when I was inspecting behind the dash.. Will check today for sure... Thanks for help, really appreciate it..Now, have to contact Evinrude and see what Faria gauge will work with this engine...Local Evinrude mech. not sure of this either. Seems to me that most Faria should work if they are for OMC, Evinrude o/b. Maybe should post this question also...
Sonny.
  #5
Old July 27th, 2008, 11:48 AM
Quote:
2nd Reply: You were exactly right...Seperate bundle under the dash with the wires you described above, no problem now to hook up gauge.
Captain should be in charge of Evinrude E-TEC tech. division, knows more than mech. do who work on Evinrude engines every day..
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude e-tec 90 hp prop selection bucks or bass ? Prop Questions and Topics 4 January 4th, 2008 10:23 PM
2004 Evinrude E-TEC 90 HP intermittently won't throttle back bmfresq Johnson & Evinrude Outboards 8 May 25th, 2005 02:07 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
