  #1
Old July 25th, 2008, 01:39 PM
gmarshall43 gmarshall43 is offline
Default '64 evinrude runs better with cover off.
I have a 1964 Evinrude, 6hp. It will start up and idle fine. It will run good in gear at low speed but when it has runned at full throttle for a few minutes it will began to slow down. I took the cover off while it was running and it began to run faster. I put the cover back on and it slowed down again. I thought this might be heat related but the water pump is spitting out water well. Any suggestions?
Thanks
  #2
Old July 25th, 2008, 01:43 PM
ftltony's Avatar
ftltony ftltony is offline
Default Re: '64 evinrude runs better with cover off.
Leave the cover off!!!!
Look for the "vent holes" on the cover, sounds like they are blocked.
__________________
Hold My Beer And Watch This!
  #3
Old July 25th, 2008, 01:46 PM
Xcusme Xcusme is offline
Classic symptom of a leaking exhaust gasket allowing exhaust to foul the fresh air into the carbs.
  #4
Old July 25th, 2008, 01:51 PM
F_R F_R is offline
Even more classic symptoms of somebody running it in a barrel. Are you?
  #5
Old July 25th, 2008, 01:54 PM
ftltony's Avatar
Quote:
Explain that one......? I have run motors in barrels and never experienced this.
__________________
  #6
Old July 25th, 2008, 01:59 PM
clemsonfor clemsonfor is offline
Agree with both most likely a blown exhaust gasket or blocked air passage. Running in a barrel at WOT or near it makes lots of exhaust and with the motor not moving it boils out from around the motor and clouds around it so even if sucking air right it sucks exhaust.
-nate
  #7
Old July 26th, 2008, 05:43 PM
yes I am running it in a barrel. I will be running it on a lake this next week. I'll be sure to check the exhuast gasket.. thanks
  #8
Old July 26th, 2008, 07:42 PM
F_R F_R is offline
Breathing even a little bit of it's own exhaust smoke has a drastic effect on performance. The air intake is below the cowling so it is just like sticking it's nose down into the barrel. With the hood off it can breathe air from higher up.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
70 Johnson Only Runs With cover off sat1962 Johnson & Evinrude Outboards 7 June 8th, 2008 09:38 PM
Engine runs good without cover on, with cover runs bad sxm_tj Johnson & Evinrude Outboards 4 September 22nd, 2007 01:35 PM
1989 150 Evinrude head cover & Therm cover torque specs? pza Johnson & Evinrude Outboards 1 July 30th, 2007 11:54 AM
70hp Johnson runs (rough) w/Cover off GeneOC Johnson & Evinrude Outboards 4 August 13th, 2002 03:25 PM
honda 7.5 runs rough with cover on bobdanielak Honda & Tohatsu/Nissan Outboards 13 June 28th, 2001 11:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
