  #1
Old July 25th, 2008, 12:42 AM
Windsong Windsong is offline
Default How to replace impeller on a 4.5 hp Mercury?
We think the impeller on our 4.5 hp Mercury needs to be replaced. The serial number is 7213211 - we checked this on the chart to find the year of the motor, but it is not on the chart. Can you tell us how to access the impeller so that we can replace it? We have searched and found answers to this question, but they haven't been specific enough. Any help, such as where to access a diagram of the motor, would be greatly appreciated.
Thanks,
Windsong
  #2
Old July 25th, 2008, 07:55 AM
rightcoastrob rightcoastrob is offline
Default Re: How to replace impeller on a 4.5 hp Mercury?
im not sure on your 4.5 but on my 115 i had to take the lower end off it was like 5 bolts and it slid apart mine bolted togther right above the prop.im sure yours is similar.it sounds intimadating but its actually pretty easy.i had a hard time getting the impeller off the shaft but other then that i could do one in an hr bye myself.i belive this is your impeller also id double check tho >> 18-3239 im a newbie myself so id get a second opinion before i spent any cash on parts.
  #3
Old July 25th, 2008, 08:18 AM
Thanks, we will try that.
Windsong
  #4
Old December 4th, 2008, 09:19 PM
JIMHAY97 JIMHAY97 is offline
I have a 1977 Model 45 that also needs a new impeller. I've taken the 2 nuts loose from the cavitation plate but cannot seperate the lower unit from the rest of the engine. I can get maybe a 1/16" gap but that is all.
The manual says that I should take the propeller off first. Is that necessary? Hope not because the nut will not turn, even with an impact driver.
If the splines are rusted together inside is there a way to get some penentrating oil into them?
Any help or wisdom would sure be appreciated.
Jim
  #5
Old December 5th, 2008, 10:59 AM
dennyb123 dennyb123 is offline
Going by the chart on one of the links posted in this forum, I believe it is a 1984 Canadian made 4.5 hp.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
How easy is it to replace the impeller lp142 Mercury & Mariner Outboards 7 June 6th, 2007 04:12 PM
How to replace the impeller on an '03- 30 hp? hellbent2fish Honda & Tohatsu/Nissan Outboards 1 November 5th, 2006 02:03 PM
How to replace impeller? texaz Johnson & Evinrude Outboards 12 June 1st, 2006 11:55 AM
how often should i replace the impeller aggiedave98 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 April 18th, 2005 11:27 AM
How to replace impeller in 78 mercury? jsp123 Mercury & Mariner Outboards 3 June 4th, 2003 10:24 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
