JoLin
- Aug 18, 2007
- 5,146
Okay, I'm stumped.
The issue is that my motor has normal temperature (160 deg) at idle and low speed, but runs hot (180-190) at high rpms.
The water pump is rebuilt and pumping fine.
The gauge seems to be fine, also. The motor comes off fast idle right at a reading of 140 (t-stats open at 143), and the needle is right where it oughta be at warm idle (160).
I searched the forum and read that this condition indicates that the cooling pressure relief valve(s) in the head(s) may be stuck closed. Sounds reasonable to me.
My dilemma is that Seloc says I have 'em but doesn't show them, the OMC shop manual doesn't mention them at all, and my OMC parts catalog doesn't show anything in the powerhead that looks to me like a cooling relief valve, nor do any of the exploded parts carry that description. Went to the Evinrude site, but that's just a repeat of what's in the parts catalog. No help there, either.
Anyone out there familar with this particular motor, or the 150 hp, which is essentially the same? Do I have these valves or don't I? I simply can't figure out exactly what I'm looking for, where it/they are located, or how to remove/replace it/them.
Thanks!
Thanks!
