  #1
Old July 24th, 2008, 05:57 PM
Double- Double- is offline
Default 1973 9.8 Mercury won't start. Fuel, Spark & Compression all good
This motor has about 110 pounds of compression in both cylinders. The spark is bright blue and has new plugs. Carb cleaned, but did not really need to be.
This motor still will not start, even with a squirt of fuel mix in the carb, or with a squirt in each cylinder.
The flywheel key is good.
Has anyone seen a hidden blown gasket issue, air leak or a drastic timing issue I am overlooking? Am I missing something else?
Thanks in advance-
  #2
Old July 24th, 2008, 07:09 PM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
Default Re: 1973 9.8 Mercury won't start. Fuel, Spark & Compression all good
In principle, if the fuel, spark, and compression are good, then it should run. Perhaps the spark is not really as "good" as you think, due to bad timing, mis-adjusted linkage, etc.
You don't say if the motor used to run fine and just stopped on you or if you just got the motor and are trying to start it for the first time. If you never had it running before, I would suggest doing/checking all of the link and sync steps to make sure everything is correct. If the motor ran fine before and then it just stopped on you, then I would suggest that you describe how that happened to provide some more clues.
Just my thoughts...
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
  #3
Old July 24th, 2008, 07:19 PM
Laddies Laddies is offline
Check for a bad flywheel key.
  #4
Old July 24th, 2008, 08:27 PM
Thanks for the responses.
This motor is new to me. The old owner "said" it was put away running, but now wont start.
The motor is in really nice shape and does not appear to have ever been "tinkered" on. All linkage is tight and in original location and in very good condition. I will have to get a book to check linkage adjustments to be certain however.
  #5
Old July 24th, 2008, 08:45 PM
JB's Avatar
JB JB is offline
How long ago was it "put up"?
Sure sounds like a timing or synch problem.
__________________
RED SKY at night. . .
JB
  #6
Old July 24th, 2008, 09:00 PM
This_lil_fishy's Avatar
This_lil_fishy This_lil_fishy is offline
Do a compression check....no compression no vrrroooom.
Actually that's about all that's left to check. Otherwise it's definately a spark issue. Even if it wasn't firing at the right time you'd eventually get some backfiring or sputtering.
Ian
  #7
Old July 24th, 2008, 09:29 PM
Are the plug wires reversed
  #8
Old July 25th, 2008, 12:03 AM
JB's Avatar
JB JB is offline
Does anybody really read the original post???
The compression is about 110psi in both cylinders.
He said that twice.
What does that leave?
Possibly timing waaaay off, but not enough to make her backfire.
Could poor or no scavenging not be providing enough air for combustion??
__________________
JB
  #9
Old July 25th, 2008, 10:24 AM
The old owner says he put it away about 1-2 years ago. I tend to believe that due to the bad gas in the tank that was not totally "varnish".
The plug wires are not long enough to be reversed, but great thought!
I tend to agree that the timing would have to be VERY off not to get any kind of firing at all. I like the idea of poor scavenging. Are you thinking some kind of blockage somewhere internally?
  #10
Old July 25th, 2008, 11:30 AM
JB's Avatar
JB JB is offline
Yes. I am thinking something jamming up the reeds or a dried out gasket not allowing crankcase compression.
__________________
JB
  #11
Old July 25th, 2008, 11:32 AM
allymoss allymoss is offline
Send a message via MSN to allymoss
make sure gap of plug is right, screwed in enough.
if its nothing else then it must be timing. As said before, go through link sync procedure even if it looks ok.
__________________
Seagull Outboards, I work on the principal that they are never "dead"
By the way, my pic is of part of my Seagull outboard collection! 45 or something there.
  #12
Old July 25th, 2008, 11:43 AM
oldtruckface oldtruckface is offline
to start your motor spray some deep creep into the carb.you can get it at napa
  #13
Old July 28th, 2008, 02:22 AM
hkeiner's Avatar
Ensign
Quote:
The spark is bright blue and has new plugs. This motor still will not start, even with a squirt of fuel mix in the carb, or with a squirt in each cylinder.
Perhaps you can clarify what you are experiencing when you say you are spraying some fuel mix into the carbs/cylinders and it won't start.
1) Are you cranking the motor while you are spraying the fuel into the carbs or are you spraying and then cranking? You should be spaying while the motor is cranking to see what happens.
2) Does the motor not respond at all (while spraying the fuel into the carbs while cranking the motor) or does it respond a little but not "start" running on its own? These two different possible situations lead to totally different groups of probable causes.
Just thought this might help...
If you are correctly spraying the fuel while cranking the motor, you have a good spark, and the motor does not respond at all, I think that JB's opinion that "something is jamming up the reeds or a dried out gasket not allowing crankcase compression" is the most likely situation. I don't know how to test for this without disassembly of the motor. Perhaps someone else might suggest a quick and easy test for this, such as holding something in front of the carb throat while cranking to see if there is any suction?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1973 50hp no start no spark one cylinder shorehugger14 Johnson & Evinrude Outboards 8 July 5th, 2008 04:01 PM
Mercury 50hp 3 cylinder - Fuel, Spark, 120psi compression - No Start bigshrimpin Mercury & Mariner Outboards 3 May 27th, 2007 06:30 PM
Good spark and compression, one cylinder only Pianh Johnson & Evinrude Outboards 9 September 27th, 2003 04:42 AM
1973 80hp mercury any good? wishinIwasFishin Mercury & Mariner Outboards 3 December 29th, 2002 10:17 AM
no spark-no start! evenrude 50 hp 1973 hamlove1 Non-Repair Outboard Discussions 1 August 22nd, 2002 06:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
