  #1
Old July 24th, 2008, 04:28 PM
steve62 steve62 is offline
Send a message via Skype™ to steve62
Default 1977 Evinrude 55 HP leaking lower unit
On the lower unit on both sieds there are water inlets. Well it's where the earmuffs go on..lol On the right side there is a set screw and a second hole below it. The set screw was leaking gear oil like mad. I removed the screw and when re-installing it added a little marine goop to the threads for the last 1/4 inch or so. There's no fluid coming from there. There is however fluid still escaping from a small hole below this set screw. Any ideas on how to stop it or what's causing it?
Anothehr fella refilled the lower unit for me with gear oil. He did this with the unit verticle. He pumped fluid in from the bottom until it leaked from the top fill plug. Could this have overfilled the lower unit or was this the proper way to fill it? The reason I ask is that my super sea horse 40 requires the lower unit to be lifted to the horizontal then filled from the lower drain until there is fluid coming from the upper plug. If that's the case here then this thing may be way overfull????
Any help is appreciated. If it would hep I could take photos of this unit and post them here.
BTW this is all happening with the boat in the backyard not in the water.
__________________
If it ain't broke...fix it til it is!
  #2
Old July 24th, 2008, 06:27 PM
yellowbelly's Avatar
yellowbelly yellowbelly is offline
Default Re: 1977 Evinrude 55 HP leaking lower unit
it states in the manual never take the set screw out its the pinion bearing u have to disassemble the lower unit to put it back right
  #3
Old July 24th, 2008, 08:43 PM
kjdunne kjdunne is offline
Filling the LU from the bottom until it runs out the top hole with the engine vertical is the correct procedure. Replace the o-rings or washers on the plugs EVERY time they are removed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1977 evinrude 75 HP lower unit doesn't drop waterboot Johnson & Evinrude Outboards 6 July 26th, 2008 11:39 AM
1977 Johnson 55 hp lower unit won't drop estatevega Johnson & Evinrude Outboards 1 July 3rd, 2008 11:36 AM
55 HP Electric Shift Evinrude '68 Lower Unit Heinze Johnson & Evinrude Outboards 9 December 17th, 2004 01:03 AM
1986 225 hp Evinrude Lower Unit Leaking SHamble Johnson & Evinrude Outboards 3 June 7th, 2004 06:48 PM
My 1977 35 hp Evinrude lower unit Raymond1 Johnson & Evinrude Outboards 1 July 26th, 2002 02:44 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
