insideoute
- Jun 28, 2008
- 2
I have a 115 hp mercury o/b the part of the motor facing the bow says mercury Kiekhaefer thunder bolt ignition and the top panel of the motor says 1150 now the part mounts on the transom only has a serial number on it and it is 3528540 I have no idea what the year is and i have water droplets on the spark plug that goes to #4 cyclinder i have no water showing on any other cylinders. I found this out because when i was on the lake and got on it it bogged down qnd died but would start right up no problem but when you go to get on it it dies and you have to feather the throttle back and forth to get it to full throttle so i brought it home and pulled all the spark plugs and found that. Also the idle seems a little high it idles between 1000 and 1100. any help would help
