Re: Engine damaged car crash
Is that just the way the trailor looks in the picture or was the lower end of the engine slammed against the trailor? It looks like the trailor is bent in the picture like the lower side was pushed into the trailor, If it was I would definately suspect Transom damage.
As far as the motor, I would bet everything from the base of the powerhead down would need to be checked if not replaced. Drive shaft most likely bent, probably cracked the mid caseing due to the force on the lower side. May have even done slightly damage around the transom mount. It couldnt hurt to go ahead and closely look over the powerhead. Probably didnt hurt it but cant hurt to be sure.
Was it her fault? If so, Id wait on the Ins settlement then worry bout fixing the motor, you may not have to even worry bout it. If Im looking at the pic correctly it looks like she hit you fairly hard. My dad runs a body shop/ fiberglass shop and does boat repairs. Judgeing by what Ive seen at his shop I would say you are looking at close to 65% what the motor is worth plus transom repair costs. Normally they figure transom repair in on something like what you have. We had one that looked similiar from a guy that hit a stump, the Ins paid to redoe the transom but as we tore it out we found no issues. Also, if that is trailor damage they will take care of that as well.
Robert
