  #1
Old July 24th, 2008, 09:28 AM
waterboot waterboot is offline
Default 1977 evinrude 75 HP lower unit doesn't drop
I want to change the the prop on the waterpump. Took all 6 bolts out on lower unit. drops 1/2 inch and stops. Looks like the rod going up to the engine is attached to the lower unit. What should I do to make it drop?
Thanks
  #2
Old July 24th, 2008, 10:46 AM
wilde1j wilde1j is offline
Default Re: 1977 evinrude 75 HP lower unit doesn't drop
Shift rod needs to be disconnected. An OEM shop manual will show exactly how.
__________________
Jim
  #3
Old July 24th, 2008, 12:19 PM
ottertail ottertail is offline
Look under the bottom carb and you will find the shift rod connector mentioned above
__________________
"It's no fun if the boat don't run!"
  #4
Old July 24th, 2008, 03:03 PM
Randybeall's Avatar
Randybeall Randybeall is offline
As suggested already, a shop manuel should be in your hands before starting this kind of work. It is possible to mess up the sift rod adjustment in the process. When you get through, change the lower unit oil. That will let you feel confidant that the pump and lower unit are in good order before going back out. Nothing like draining a lower unit and finding a chocolate milk shake when you just had the thing off and could have done a reseal while it was off for the water pump impeller.
  #5
Old July 25th, 2008, 01:17 PM
Quote:
Dropped the unit, after disconnecting rod under carburator. How could I mess up the shift rod if I put the rod back in the same hole Where I took the bolt out?
Also rubber propellor seemed to fit snug. Had to bent the rubber to get it in place. After changing waterpump and put a thermostat in which there was none there it seems that there is very little water coming out of the holes. Only noted water coming out of small hole opposite of the proppelor. Did not see this before? How do I know waterpump is working correct?
Thanks
  #6
Old July 25th, 2008, 01:29 PM
ftltony's Avatar
ftltony ftltony is offline
You are supposed to have to bend those fingers into place when you put a new impeller in, thats how it gets the water pressure going. Pump technology, Lots of fun!
As far as your "little or no water" flow issue, did you run it with the ears on and did you let it heat up to the right temperature so that the thermostat would open?
Did you install an entire Water Pump Kit...?
Was your motor "pee-ing" out the pee hole?
... and don't be concerned too much, some people seem to forget that this board is for helping people with motor problems and they would rather CHASTIZE you for not having a shop manual as opposed to like ... giving information that might help you! After all, its easier to criticize than it is to help but, thats how some people live their lives.
__________________
Hold My Beer And Watch This!
  #7
Old July 26th, 2008, 11:39 AM
replaced the whole kit with steel plate's etc. Does it matter which direction you bent the fans? ran it on both muflers and in a tub. With the muflers I get quit a bit of water coming out when its in the tub only when I ref the engine but I don't want to do that to long. I replaced the thermostat but the relief valve is missing can't seem to find the part online. Not sure how critical it is. Did find the sercvice manual did not know I had it but doesn't show every step either.
Is the pee hole a small hole which it between the gearcase and exhaust housing oposite of the trimtab and proppelor? Did not see water here before but maybe it was plugged.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1977 Johnson 55 hp lower unit won't drop estatevega Johnson & Evinrude Outboards 1 July 3rd, 2008 11:36 AM
1977 Evinrude 55hp 2cylinder do I need to dissconnect gear linkage to drop lower unit zaner Johnson & Evinrude Outboards 2 May 20th, 2007 08:11 PM
Lower Unit Won't Drop - 1977 40hp aquab0y424 Mercury & Mariner Outboards 3 May 28th, 2005 10:44 AM
75 hp evinrude lower unit muffmooch Johnson & Evinrude Outboards 4 November 4th, 2003 05:15 PM
My 1977 35 hp Evinrude lower unit Raymond1 Johnson & Evinrude Outboards 1 July 26th, 2002 02:44 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
