  #1
Old July 23rd, 2008, 08:44 PM
Riknar Riknar is offline
Default Mercury 650 All Throttle, no motion..no gear
Okay...what a night. I bought a boat recently, and after spending days prepping it for launch, my son finally convinced me.
Into the water it went.
Started like a dream. I hit the throttle..and NOTHING
no forward, no reverse.
FUNNY thing is, after paddling my guts out to get back to the dock...I lifted the motor, started it..and watched the prop spin wildly.
I remembered that at home..when the motor was down, the prop spun freely by hand...but UP...it would lock.
Someone out there, please tell me what I need to do to fix this...or direct me to proper instructions.
I know the 650 is famous for losing it's gears.
I need some good instructions..in layman's terms...
I am pretty handy...and have done this work before, just not sure what all the technical terms and names are.
thanks!
  #2
Old July 23rd, 2008, 08:49 PM
Default Re: Mercury 650 All Throttle, no motion..no gear
OH YEAH...so you know, it is a 1966 4 cyl 650
  #3
Old July 23rd, 2008, 08:59 PM
CharlieB CharlieB is offline
In the driveway, key OFF, disconnect the shift cable, while turning the prop with your foot manually shift it into forward and reverse to see if the gearcase locks into each gear.
If yes then if may be a matter of replacing/adjusting your shift cable.
  #4
Old July 23rd, 2008, 09:20 PM
thanks...I will try that.
I just find it strange that when the motor is down, the prop spins free in both directions..in neutral..and when up, it locks one way and ratchets the other...
still in neutral.
and it does not change if I move it into gear.
I will try what you are saying, see if that helps.
thanks
  #5
Old July 23rd, 2008, 09:30 PM
UPDATE
Removed the covers and checked the motion of the throttle and shifter cables. The shifter moves perfectly...right as it is supposed to..but I DID notice that the throttle moved a GREAT amount in reverse..and barely moved in forward.
Any ideas on THIS now?
  #6
Old July 23rd, 2008, 09:36 PM
boatmonkey82 boatmonkey82 is offline
simple .... some one did not line up the shift linkage when they put the lower unit back on .so drop your unit and find neutral gear . then line it up with your shift rod and on your model it twist into and out of gear instead of pull up and push down like the omcs . you may have to twist the shift rod a bit to get the splines to line up and there you go . it sounds like this is your prob since when you tilt it up the clutch moves into gear from gravity and when you let the motor down it pops back out or the other way around regardless mercruisers are bad for this and you have to hold tension on the prop shaft while its in gear to keep it there. if none of this works and you have tried unhooking the shift cable and manualy shifting it then it may time to go into the lower unit
  #7
Old July 25th, 2008, 09:05 AM
UPDATE!
Okay, so I removed the Lower unit...was harder than I thought, but I got it done.
The shift shaft was spinning rather freely, except when it would reach a certain point...I used a socket, the same size as the shaft to turn it, so it would click in and seat.
I did it a couple of times until the prop spun freely.
Then I put it all together again...
when I did, there was a rather larger snap sound as it was coming together...which worries me...
did I bust the drive shaft maybe?
Anyway...all back together, I shifted, and tested the prop...
STILL spins freely in both directions..no change...and now, it seems as though it CLUNKS when I spin it.
ANY ideas?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 650 - Outboard - Gear Housing addams_21 Mercury & Mariner Outboards 8 March 28th, 2005 04:57 AM
650 hp Mercury HELP!- gear stripped on driveshaft seawolfofspokane Mercury & Mariner Outboards 3 July 23rd, 2003 06:25 PM
60 Mercury stalls when given throttle in gear Shane Oliver Mercury & Mariner Outboards 3 February 18th, 2003 02:21 PM
1976 Mercury 650- 65 HP won't shut off, dies in full throttle. blueskies401 Mercury & Mariner Outboards 2 July 22nd, 2002 12:50 PM
'74 Mercury 650 - Hard to get into Reverse Gear Embee Mercury & Mariner Outboards 0 July 12th, 2001 02:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
