  #1
Old July 22nd, 2008, 06:52 AM
thetinman72fl thetinman72fl is offline
Default yamaha 115 not idling
In regards to an earlier post of mine, could the fact that I get gas squirting out of my fuel filter when I squeeze the bulb hard cause it to not idle, but run ok at wot?
  #2
Old July 22nd, 2008, 10:18 AM
douglloyd douglloyd is offline
Default Re: yamaha 115 not idling
Wow that's not supposed to happen.
But 9 times out of ten it's dirty carbs.
Clean carbs inspect fuel system for leaks.
  #3
Old July 22nd, 2008, 01:39 PM
Well, the carbs were rebuilt at the beginning of this season, the only leaks I can find are when I squeeze the bulb, gas squirts out of the fuel filter assembly, engine won't idle unless someone sits in back and lightly squeezes the bulb or I lightly hit the choke to smooth out the idle, then I can open her up and go.
  #4
Old July 22nd, 2008, 09:45 PM
Yamajoe's Avatar
Yamajoe Yamajoe is offline
You need to fix that fuel leak at filter as the system is sucking in air, not good for your pumps, carbs and motor and dangerous.
  #5
Old July 22nd, 2008, 11:56 PM
BruceAML BruceAML is offline
Send a message via AIM to BruceAML
Please post your complete model number. Is this the factory fuel filter? Where on the filter does it leak? This is very dangerous and needs to be corrected.
  #6
Old July 23rd, 2008, 06:50 AM
I'll find the model number later today,I'm at work right now, but it is a 115 2 stroke, 1989. It appears to be the stock little plastic threaded fuel filter thing right in front of the fuel pump. I just bought this boat on consignment from the local dealership this season. I didn't see any o-ring or any other type of seal inside there like I thought should be there. It leaks when you squeeze the bulb at the union where the bottom part threads onto the top. This is my first boat, never worked on them before, obviously. Built bikes and cars all my life, this is all new territory.
Thanks,
John
  #7
Old July 23rd, 2008, 02:44 PM
bustab bustab is offline
just worked on a yamaha 40 with a fuel leak at the fuel connect at the motor. ran rough at all rpm....fixed the leak....runs great at all rpm
  #8
Old July 23rd, 2008, 07:16 PM
OK, my engine is a 1989 yamaha 115 etlf, at least thats what the previous owner has written in the owner manual, although the manual is for 115 etg, 150 etg, etc.
  #9
Old July 23rd, 2008, 08:39 PM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
fix that leak
it will cause that motor to run like sheet
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #10
Old July 23rd, 2008, 09:21 PM
Problem is, the filter container is tight. Not really sure if there is supposed to be an o-ring in there or not, but I didn't see one, think I'll just get rid of it and run an in-line after the bulb and a water separator filter before the bulb. Think that will work?
  #11
Old July 23rd, 2008, 09:27 PM
JUSTINTIME's Avatar
should have an o-ring
__________________
  #12
Old July 23rd, 2008, 09:59 PM
Yes but you better have a 10 micron Racor in front of it.
  #13
Old July 24th, 2008, 02:49 PM
The filter has an o-ring and a gasket. Order a new complete filter with this part number [6R3-24560-00-00]. This is an updated part number and you should not have any more problems. It is not a good idea to remove the filter.
  #14
Old July 24th, 2008, 03:46 PM
Thanks for all the help. I'll be changing that filter out and running her this weekend. Where'd you get that part number, by the way, Bruce? Sure could use a book like that.
  #15
Old July 25th, 2008, 08:35 AM
You can go online to the Yamaha factory web site. You can look up part numbers but the parts must be ordered from a dealer. You need to know your year and model. Here is the link:
http://www.yamaha-motor.com/outboard/parts/home.aspx
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 115 problem idling skgtoy91 Mercury & Mariner Outboards 0 July 15th, 2008 09:16 PM
1995 115 Ocean Pro idling rough fireman57 Johnson & Evinrude Outboards 1 June 30th, 2006 12:40 AM
115 SPL Overheat alarm comes on after 5 minutes idling? martymudskipper Johnson & Evinrude Outboards 3 October 12th, 2005 07:52 AM
115 starting/idling problem Thongpoon Johnson & Evinrude Outboards 3 August 11th, 2004 08:26 PM
1982 Johnson 115 starting and idling problems LAW0412 Johnson & Evinrude Outboards 1 May 6th, 2002 09:16 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
