'85 Force 85hp, series: 856X5L
Strange happenings with my engine.
Sometimes when I get it started, starts on the first try these days , it won?t make full rpm.
It idles fine but will only reach 2400rpm wide open. I fiddle with the throttle and the choke. Stop and restart it. Eventually it will run correctly and reach 5300rpm wide open.
? 122psi compression all cylinders
? Butterflies all open
? Number 2 spark plug is clean and shinny, 1 and 3 are dark.
Am I right that a clean spark plug is a sign of no spark or no fuel?
So I'm thinking:
1. Bad coil pack or control box in that cylinder. (Control box is shared with number 1 and it's fine.)
2. Poor fuel delivery to that cylinder. Number 2 carb rebuild.
So I'm thinking:
