  #1
Old July 21st, 2008, 09:47 PM
route66_garage route66_garage is offline
Default 9.9 Evinrude fuel issue
I recently purchased a 1978 Evinrude 9.9 outboard and have it on a small 16' pontoon boat. It starts right up and runs out great. The problem: After a few minutes of running, at any speed, the motor stops running. If I try to start it without pumping the fuel primer ball, it will not restart. If I pump the primer ball, it starts right up again, runs great for a few minutes and stops again. The ball, after it stops feels soft again, but it pumps right up. It is obviously a fuel delivery related problem but here is what I have done so far. Put a new fuel pump on it. Rebuilt the carb. Tried three different fuel tanks, with new gas, vents open and closed. Tried three different fuel lines with new bulbs. Two 3/8" and a brand new 5/16" ( a real Evinrude hose and bulb ). Cut the new hose down so the hose was shorter. Brought the tank onboard so it was at a higher elevation. I know the fuel pump works with cylinder compression, but the motor runs great with a lot of power when running? The water pump works fine and the motor does not run hot. If I catch it before it actually dies, and pump the ball, it stays running so it can't be electrical. Thanks in advance for any help you guys can share with me. Dave
  #2
Old July 21st, 2008, 09:54 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Default Re: 9.9 Evinrude fuel issue
Welcome to iboats.
Your fuel pump is not functioning for whatever reason. Did you rebuild it?
__________________
Chris
  #3
Old July 21st, 2008, 09:55 PM
samo_ott's Avatar
samo_ott samo_ott is offline
Wow. You sure have done everything I would have suggested. It sure does sound like a fuel delivery problem. Have you tried pulling the hose off the fuel pump exit to make sure it actually is pumping into a pail or something? Slim chance but not sure what else to offer. You must be pretty frustrated.
__________________
Steve.
  #4
Old July 21st, 2008, 10:04 PM
Vic.S's Avatar
Vic.S Vic.S is offline
Air leak into the fuel line either at the connector or on the hose from there to the fuel pump?
Air leak on the filter? Any signs of gas leaking from any of those places when the bulb is pumped.
Pump not pumping for some reason. !!!
BTW the bulb wiil not stay hard while the engine is running.
__________________
If it aint broke dont fix it!
If all else fails read the manual
  #5
Old July 21st, 2008, 10:05 PM
Have not tried removing the hose but will do next time I am on it. I actually bought a brand new "complete" fuel pump and it was not cheap. One thing though. The inlet and outlets were at a different angle on the new pump. Took it apart and spun the base to the right configuration to match the old one. I know I got it back togther right. Assumed it was a universal style pump? What about those small 12 volt electric, low pressure, fuel pumps made by Sierra Marine for outboards? Anyone ever used one? Dave
  #6
Old July 21st, 2008, 10:20 PM
HighTrim's Avatar
Which pump did you get? Part number?
__________________
Chris
  #7
Old July 21st, 2008, 10:22 PM
HighTrim's Avatar
Have a look here
http://www.sschapterpsa.com/rambling...g_fuelpump.htm
__________________
Chris
  #8
Old July 22nd, 2008, 08:31 AM
Thanks so much High Trim. I believe with the info you sent, I should be able to get her going. Will try this coming weekend. Dave
  #9
Old July 22nd, 2008, 11:42 PM
It is fixed!!! Thanks to all of you for your help, especially high trim for the pump breakdown link, which actually showed me what was wrong with the pump assembly. Dave
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1985 Evinrude 120hp V4 Fuel Issue? **UPDATED AGAIN** hilikus Johnson & Evinrude Outboards 14 September 19th, 2007 10:31 PM
fuel pump issue 82 evinrude 150hp V6 cb950 Johnson & Evinrude Outboards 3 April 7th, 2005 01:36 PM
Fuel Issue/Primer Bulb? Fuel Line? Pump? ShawnQ Johnson & Evinrude Outboards 4 July 21st, 2004 08:41 AM
Engine dies after long runs (fuel issue), fuel hose? ShawnQ Johnson & Evinrude Outboards 8 March 19th, 2004 02:12 PM
Spring helped, Fuel bulb ??74 Evinrude 115 Choke issue? Pst76 Johnson & Evinrude Outboards 8 September 6th, 2002 05:45 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
