  #1
Old July 21st, 2008, 09:29 PM
rice rice is offline
Default mariner 5 running super hot...
hi everyone. i just picked up a single cylinder 5hp mariner for a kicker for my fishing boat. i believe it is early 90's but not too sure as i cannot find the model number. it started first pull, and ran good in a bucket. but the motor runs extremely hot. it has a telltale that has alot of flow but the water coming out seems to be about the same temperature as the water in the bucket. it does not seem to be removing the heat. when i put a bit of water on the head after idling for about 10 minutes it started to steam. if i put water on the exposed part of the spark plug just after the rubber cap it almost sizzles. you cannot put your hand there for even a miliseccond.
does anyone know if there would be a thermostat in there somewhere? i have done some searching and i dont think there is one.
does anyone know if small single cylinders like this are supposto run hot like this?
any ideas?
thanks in advance
  #2
Old July 22nd, 2008, 08:16 PM
Default Re: mariner 5 running super hot...
too many threads. hard to get attention.
please help
  #3
Old July 22nd, 2008, 11:13 PM
anyone????
  #4
Old July 23rd, 2008, 02:40 AM
emckelvy emckelvy is offline
Definitely should not be running that hot. Don't think it has a thermostat but without a serial number hard to tell. Check all over the block for stamped numbers or something that looks like a ser #.
Take a look at the various parts diagrams for 5HP and maybe you can find your motor:
http://www.mercruiserparts.com/Selec...asp?class_id=2
If you find the motor has no thermostat, most likely the overheating is being caused by a blown head gasket or plugged cooling passages. You'll have to remove the cylinder head to inspect for that.
Be sure to install a new head gasket and also check the head for warpage by laying a straightedge across it in various positions and see if you can slip a thin (approx .001" or .0015") feeler gage under the straightedge.
If the head gasket is obviously leaking or the head is warped, the head should be 'surfaced' to ensure it's perfectly flat.
This can be done by a good automotive machine shop, or you can take some medium-grit sandpaper and 'dress' the head on a flat piece of glass.
It's probably quite easy to pull the lower unit off, you could inspect the impeller and blow compressed air up the water tube to check for obstructions while the head's off.
Note that the head bolts should be torqued upon reinstallation. Re-torque the bolts to specs after you run it for the first time and it's cooled down. And it's a good idea to re-torque the head bolts once a season after that. Put a thin coating of waterproof grease or Permatex Aviation-type Gasket Dressing on the head bolts to keep them from seizing-up in the block.
Let us know what you find out..........ed
  #5
Old July 25th, 2008, 09:05 PM
thanks for the reply emckelvy. the head gasket was fine, no warpage, i cant see a thermostat anywhere. the engine is still running ok just hot. the water passages are all clear. it looks brand new in there.
there is a silver shiny disk about the size of a thermostat on the side of the block. does anyone know if there might be a thermostat behind there and if so how to get it out. i dont know what elce it could be. its just a round silver disk about the size of a loonie. it looks like its just pressed in there. thanks again for the help
  #6
Old July 25th, 2008, 10:42 PM
The silver disc may be for the model serial #, is there anything printed on it?
And it's probably time to pull the lower unit and check the impeller and pump housing out, blow air up the water tube, etc. to try and narrow down the problem........ed
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1991 200 hp Mariner running hot JLowe59 Mercury & Mariner Outboards 5 September 23rd, 2007 11:39 PM
93 MAGNUM 40 MARINER ...RUNNING HOT RICKYC53 Mercury & Mariner Outboards 16 January 13th, 2007 10:53 PM
Mariner 150 still running HOT. rocks Mercury & Mariner Outboards 8 July 10th, 2005 05:54 AM
Super poor running force 50 shindig888 Force & Chrysler Outboards 11 June 23rd, 2005 10:41 PM
1965 Johnson Super-sea horse NOT RUNNING!! HELP tmlee Johnson & Evinrude Outboards 6 April 23rd, 2003 09:30 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
