mercury 850 thunderbolt timing problem
I have a 850 thunderbolt merc when in neutral it runs smooth and throttles up fine, but when you put it in gear in the water and the engine has to push the boat it doesnt have any power, it only acts this way when there is strain on the motor . It idles like new and will rev up in neutral and doesnt have any problems until it has to push the weight of the boat. A guy told me that it has to be adjusted on its timing, but I dont know how to move the distributor properly becouse the distributor advances with the trottle has it revs up. someone else said it may be points, but does this engine have points, and if so would this cause the problem. thanks I hope someone can help
Cory
