Help With Flywheel Compatibility!
mjedmundson
I have a 1997 90 Force motor with a busted flywheel. I have heard some things about the 90 Force being compatible with the 120 hp Force? I'm not sure of this, but i've found a 120 hp flywheel from a 1994 motor that's available..but still not sure if it will work for my motor? Does anyone know anything about this?
jerryjerry05
Re: Help With Flywheel Compatibility!
You need to compare them side by side.Turn them over and make sure that the magnet is the same and the part in the center MUST be the same. Jerry
