First off thank to oops! And ErikGreen for shring there knowledge on this board and giving me the confidence to move forward with my project. So here it is.. A common story? I purchased a 1975 searay srv220 22? cuddy cabin 2 years ago. The owner had spent almost 4k installing a rebuilt mercrusier 233 w/ rebuilt sterndrive. 0 hours how could you go wrong !... After a year of use I decided it was time for an upgrade.. pulled the motor to install sea-star hydraulic steering. No problems there..smooth as silk now then replaced the motor? Then I noticed some the floor seemed to be checking in numerous areas. Lets jump ahead now..wet foam, water trapped below decks, Rotten rotten stringers, corroded fuel tank + fuel seepage. ? good thing I took a look? Dead boat right ? Heres the problem. I am somehow emotionally attached to this damn boat. I can?t explain it but my mission is to see it back on the water in all its glory??. Well that and the info garnered here have lead me to strip and grind (what a pita) the starboard side ala ?unintentional stringer job? problem is I couldn?t stop at the cuddy bulkhead. It was all rotten and had to go?
So now its on to the rebuild.. I hope you guys can help me answer a few questions? Here is what I know.
- I will be using West Sytem Expoxy
- I am using ?? marine grade ply for the stringers. I plan on laminating two pieces for a 1.5? stringer. (double what was there)
- Using PL to bed the stringers (more on that later)?
So here?s where I?m stuck
Can I use simple fabric to tab in and cap the stringers ? I have read a ton about bi-ax and such but I have ready access to stander 6 oz cloth. I know mat isn?t necessary for epoxy but how many layers of fabric are ? would two for the tabbing and one more to wrap suffice ? There was nothing but a thin chopper gun mat applied original on ?? ply but of course it was backed up by tons of foam (that I am not replacing). Advice is appreciated.
I will attach more pictures next post ( traveling currently w/o my camera)
