JohnnySCV
- Jun 24, 2008
- 71
I recently purchased and a 16 foot bassboat with a1978 85 HP Johnson Javelin outboard motor.
The engine istelf appears very clean, to the best of my knowledge it has never been in salt water. I know for a fact that the engine had not been started in nearly a decade, maybe more. Before starting the engine I mixed new gas 50/1 ratio. Replaced the plugs and gapped them properly per the local marine store. Replaced the fuel filter and hooked of the ears to the motor. The first three trips to the lake were great, the forth trip is were the problems started.
1) Boat lost power, even at full throttle I the boat would only rev to about 2500 RPMs
2) Sparatically it would rev up, sometime to 6000 rpms but when it did the boat would go no where.
I took the boat to a local repair shop where they cleaned and readjusted the carbs. Next trip the lake was the same thing.
Other specifics:
19" Pitch prop, lake elevation 1300', 87 octane fuel
Any thoughts on what the problem(s) could be??
Thanks in advance!
Other specifics:
Thanks in advance!
