  #1
Old July 20th, 2008, 11:50 PM
CatsRyumy CatsRyumy is offline
Default 1978 Mercury 1150 tell tale drips
I have a 1978 Mercury 115hp outboard. The tell tale is just a fast drip. The line is clear. I just replaced the water pump impeller (old one looked good too) The boat came factory with a water pressure gauge. Pressure in the water jacket runs approx 7psi at WOT... Does anyone know what pressure these are supposed to run. Is this gonna blow up on me.. Any ideas???
  #2
Old July 21st, 2008, 02:28 AM
emckelvy emckelvy is offline
Default Re: 1978 Mercury 1150 tell tale drips
How did you verify the line was clear? 7 psi will produce a mighty strong telltalle so if it's just dripping it's plugged up still.
I'd recommend giving a strong puff of compressed air up the telltale and see what that does. If it doesn't help, pull the hose off the telltale and blow that out. Water should just gush out the open-ended hose, even at idle.
If it doesn't do that, you've got some sort of circulation problem in the powerhead and you'll need to start removing covers for inspection.
The best indicator of adequate cooling underway is to lay your hand on the exterior of the exhaust manifold (big retangular plate, port side, lotsa cast-in ridges). This motor has no thermostat so if it's very uncomfortable to keep your hand on the plate, that's around 140 deg. If you can touch it but for an instant before it's too hot to bear, that's 180+ and way too hot.
Normally the exhaust manifold should be lukewarm underway to a bit warmer after a full-power run. At idle in cold water it should be stone cold or just barely warm.
7 psi is a tad low but if it's keeping the manifold cool, might be OK. It's also possible your OE gage has become inaccurate and you actually have more pressure than you think.
One of those neat little infrared thermometers from Sears or Rad Shack work great for this but the old 'hand on the equipment' method will get you there, too.
HTH & let us know what you find..........ed
  #3
Old July 22nd, 2008, 01:36 AM
Thanks for the temp info.... You can place your hand on it after running for about 15 minutes for about a second and is all you can stand it seems to be running a bit warm. Yes i have used compressed air(and have also just pulled the line and blew through it the old fashioned way) and you can hear the air come out down by the pump.. Also when you start it it has a stream coming out(although weak)...as it gets warmer(bout 4-5 minutes)...it dissappears...
I'm gonna grab another guage(and a temp guage) and check water for sure where the guage hooks up, check all the seals again coming from the pump, and just hope i dont have to pull the powerhead apart...this thing has me baffled...
Thanks!!!
  #4
Old July 22nd, 2008, 02:02 AM
When you have the lower unit off, hook up water source to the copper water supply tube.
Establish a baseline flow with the motor turned off. This should have a good stream out the telltale and of course will be gushing out the center section.
Crank 'er up and run for a few minutes. See if there's any unusual heating anywhere.
Don't throttle it up at all, just let it idle.
Be very careful 'cause there's no backpressure and no load from the pump or lower unit gears dragging, so this thing will rev like mad if you crack the throttle! Have someone at the control box ready to turn the key off in case of an emergency.
Note if the water flow changes with the motor running. I'm thinking that maybe you have some sort of exhaust gasket leak and it's pressurizing the powerhead cooling passages with exhaust gasses. This'll tend to blow all the water out of the block and make it heat up. And of course the faster you run it in the water, the higher the exhaust pressure will be.
Now, after you shut 'er down, pull all the spark plugs and check for droplets of water on them.
If you see water on any plug, it's a sure sign of leakage and I'd bet money on the exhaust manifold. Either gaskets leaking, bad baffle plate, or issues with the inner cover around the exhaust ports.
The reason I'm leaning towards this is how you describe the water flow getting weaker as the motor warms up. This is definitely not normal behavior for an Inline. They usually just pump water like crazy and run fairly cool.
If you do happen to run it in the water again before tearing into things, pull all the spark plugs, after running at a good clip then chopping the throttle to Neutral and shutting off the ign. If there's any water on them you've got issues.
Anyway, give that a shot, maybe it'll tell us something.......ed
  #5
Old July 23rd, 2008, 01:12 PM
Thanks for the knowledge.....i'll get around to checking it out one of these days and post what i find.
Thanks Again!
-Dale-
  #6
Old July 24th, 2008, 12:23 AM
jimmbo jimmbo is offline
Location: Edmonton Alberta(land of rightwing nuts), Canada
On an inline six 7psi is pretty much what a new water pump will do
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1978 115HP Mercury poor water tell-tale?? headcopter Mercury & Mariner Outboards 7 July 21st, 2008 02:09 PM
1978 Mercury 1150 Charging System jeast Mercury & Mariner Outboards 2 March 30th, 2008 09:27 AM
1978 Mercury 115HP 1150 SDFISHMAN619 Mercury & Mariner Outboards 5 August 16th, 2007 09:36 AM
1978 1150 Mercury Idles To Fast jimg984 Mercury & Mariner Outboards 1 July 28th, 2007 05:39 PM
Oil for 1978 Mercury 1150?? johnson1 Mercury & Mariner Outboards 3 May 9th, 2003 09:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
