  #1
Old July 20th, 2008, 10:00 PM
keeganfairview keeganfairview is offline
Default Mercury 650 Thunderbolt won't start/ no spark
First time poster here...I have a 67 mercury 650 Serial # 2164644. I was going down the river the other day and all of a sudden my engine died out. I took it back home and took a quick look at it and put a tester to it. It turned over but wouldnt start. Then the next day i went to start it and it didnt turn over. I was told that it might be the starter solenoid, so i replaced it. Still nothing. Then i was messing around with it a little bit and got it to turn over. Then again after a while it stopped turning over. So beside the fact of it not turning over, it has no spark. Is there a way to test each part to find out what is gone? or does someone know what it is? Any help would be great! Thanks
  #2
Old July 21st, 2008, 07:09 AM
Laddies Laddies is offline
Default Re: Mercury 650 Thunderbolt won't start/ no spark
Check the engine plug in, it sounds like a bad connection or broken wire.
  #3
Old July 21st, 2008, 07:40 PM
I have checked all wires, all connections and everything looks to be hooked up right and have a tight connection. I will try to start it and it will turn over and then a few minuters later i will try to start it again and it will not do anything will not even click. I do not even know where to start...thanks
  #4
Old July 21st, 2008, 08:21 PM
When you try to start and it won't turn over, push the choke if it clicks you have power to the switch. If you have power ck for voltage at the small solinoid wire, no volts bad switch or wire from the switch or plug in connection. Also with the switch off you need 12v at the red terminal of the switch box and with the key on 12v at the red & white terminals. If this all tests good you will need to test the CD ign.
  #5
Old July 21st, 2008, 08:51 PM
I got the engine to turn over, but still no spark? What is the CD ign??? How do i test the stator, Coil, and Switch box? Thanks
  #6
Old July 21st, 2008, 10:00 PM
Heres the test from CDI
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 1975 Thunderbolt 650 3 Cyl jeanp Mercury & Mariner Outboards 11 August 11th, 2006 11:14 AM
Mercury 650 Thunderbolt Mrcproject Mercury & Mariner Outboards 8 December 3rd, 2004 04:09 AM
650 Mercury Thunderbolt oresaway Mercury & Mariner Outboards 2 July 30th, 2003 05:26 PM
1971 mercury 650 thunderbolt ignition concern rc2 Mercury & Mariner Outboards 2 September 18th, 2002 02:07 AM
Year Of my Mercury Thunderbolt 650 65hp 2 stroke y2jericho Mercury & Mariner Outboards 5 September 7th, 2002 07:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
