fishbuster229
- Jun 24, 2008
- 2
This is my first post and hear good things about this forum and have a question on a Yamaha.I have a 1992 Yamaha 200 hp 2 stroke that reduces rpm once i get up to 3400 rpm after about 15 seconds as if its running out of fuel. recently put in E10 back in march with a new racor fuel/water separtor and the boat has been on its trailer ever since. i usually start it up once a week to keep new fuel in the bowls. but was wondering was would cause this problem? also on the clear filter before the fuel pumps ive noticed some air so i tightened and checked all my connections and everything was fine. ive checked all the spark plugs/coils to make sure they had spark and they did and my compression was at 120 and the bottom two were at 110. was wondering what was causing this? fuel/water separtor(changed but havent load tested it yet), carbs, kinks in the fuel line, high speed jet in the carbs, etc? thanks
Randy
Randy
