Re: Bilge Pump float
Yes, the pump and float should be secure. Some boats are wired with an automatic bilge pump float that does not need the switch on to work. The switch is typically used to manually turn on the pump. You can check this my turning the switch off and then go lift up the float, if it turns on no issues, the switch is for manual use if the float fails.
