1987 5.7L Merc: sometimes won't crank
thedillybar
Sometimes when I hit the key, the starter engages but won't crank (like the motor is locked up). Hit the key again and it will crank. (sometimes does, sometimes doesn't)
I don't think it's a bad battery...it's only a few months old and when it does turn over the battery is capable of turning it over for quite some time.
Dakota47
Re: 1987 5.7L Merc: sometimes won't crank
Take the starter out and have it bench tested at the local autoparts store.. prolly needs replaced.
Don S
Loose or dirty battery connections will cause that. Don't forget those cables have 2 ends.
JustJason
its probably a either a bad battery cable/connection (positive or negative) or a bad wire/connection between the keyswitch and the starter.....
or a combination of all that and a bag of chips.
