Re: Evinrude 70hp 1990 outboard motor dies when put in forward and reverse
Dies when you put it into forward or reverse, how fast? is it dying instantly? or does it run a second or 2? Put it in gear and see if you can turn the flywheel by hand, eliminate that the probem may be in the gear case. Then llok at compression, spark, sync and link and carbs.
__________________
"It's no fun if the boat don't run!"
