  #1
Old July 19th, 2008, 08:29 PM
MikePags's Avatar
MikePags MikePags is offline
Default Yamaha 98 C150 OB Starving fuel or spark?
Oh but of course it does not happen all the time making it hard to trouble shoot. The motor will run great all day, and whammo it is hard starting, having to choke it. I will give the best description as possible.
1. Cold start with choke and a little advance throttle, it will fire up, but I don't think it is firing on all 6. after a minute or two, it will start to race to 5000 rpm
2. Once warm and settled it will run great for hours, even with constant restarting for drift fishing, and will idle at 700 rpm. then WHAM. I have to choke the carbs till it coughs, open the choke and it will start, but not idle under 1500 RPM without stalling not easy docking under that sitch.
I changed Fuel/Water filter, and on board filter, with no signs of water, and fresh premium gas filled tank [BTW this is a premix setup]
I suspect not all 6 cyls are working when this happens, yes it runs rough when it does happen. I just don't know how to tell if it's fuel, or spark. where do I start, especially being it won't happen in my driveway [trailered boat] Thanks for any help.
__________________
98 Parker 2110 WA Deep V, 98 Yamaha C150, Fishing on Long Island Sound
  #2
Old July 20th, 2008, 12:02 AM
woody66912 woody66912 is offline
Default Re: Yamaha 98 C150 OB Starving fuel or spark?
it kinda sounds like crank seals or some kind of air leak.if it revs up on cold start. then later. seal/air leak is somewhat sealed by gas oil mix.while running on hose spray carb clean on crank case halves if it kills motor or slows rpm you found leak. also spray carb gaskets.and try it's not easy spray under flywheel
  #3
Old July 20th, 2008, 08:31 AM
MikePags's Avatar
Quote:
Thanks for the tip, I'll try that today ,, Mike
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Ignition Switch wiring, 98 Yami C150 OB MikePags Yamaha & Suzuki Outboards 0 May 7th, 2008 09:42 AM
'98 115 SPL Fuel Starving While Planing Out chcucktrotter@mchsi.com Johnson & Evinrude Outboards 6 June 17th, 2007 08:25 PM
Yamaha C150 BayStealth Yamaha & Suzuki Outboards 0 April 25th, 2004 07:50 AM
Gauge problem yamaha C150 graham6667 Yamaha & Suzuki Outboards 3 January 15th, 2003 04:42 AM
Gauge problem yamaha C150 graham6667 Boat Topics and Questions (not engine topics) 1 January 14th, 2003 05:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
