  #1
Old July 19th, 2008, 05:25 PM
fishdog4449's Avatar
fishdog4449 fishdog4449 is offline
Default Mercury 1150 hard shifting question
Hey guys two quick questions here
(1976 merc 1150)
1) Is there a way to make the throttle/shift handle easier to move? Couldn't find any adjustments on the controls. It takes alot to muscle it into gear, but once it's in gear the throttle moves fine. (not an engine problem, have disconnected cables at engine and still have same problem)
2)Just how bad of a "clunk" are these motors supposed to make when shifting and is there anyway to reduce the noise? Don't have a tach yet, so couldn't give you my idle speed but it seems pretty low. Running a 19P SS (which is probably some of the problem, but I see other boats with SS props not jolting the boat so much)
I'm switching back to the stock 17P aluminum anyway, so I will see if that helps.
thanks!!!
__________________
1972 Macgregor 25'
1981 Glassmaster 17 '76 Mercury 1150 tower of power
  #2
Old July 19th, 2008, 05:44 PM
honestcharlie56 honestcharlie56 is offline
Default Re: Mercury 1150 hard shifting question
pull the control box off of the boat, then take the control cables off of the box. now try to push and pull the actual cable inside the control cables themselves and see how much resistance you have, they should push/pull fairly easily, and while you are doing this, with the control cable disconnected from the conrtol box, move the control handle from full throttle forward to full throttle reverse and see how much resistance you have, it shouldnt be anything, or not much at all, if the cables/ a cable has a stiffness and doesnt wanna move then just replace it, if the box has resistance try to grease/oil it up.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 1150 powerhead removal question fishdog4449 Mercury & Mariner Outboards 12 June 16th, 2008 10:13 PM
hard shifting johncg Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 April 26th, 2008 10:49 PM
Hard shifting '94 Mercury 60HP seaway81 Mercury & Mariner Outboards 2 September 25th, 2007 05:23 PM
Hard starting 1150 - now starts great mirageflats Mercury & Mariner Outboards 0 June 12th, 2005 05:44 PM
mercury 1150 question inline 6 phatmanmike Mercury & Mariner Outboards 3 June 21st, 2004 01:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
