  #1
Old July 19th, 2008, 01:35 PM
dstobert dstobert is offline
Default 1967 Mercury twin 350 (35hp) COIL SMOKES
Hi there,
My 67 mercury 350 twin (35hp) smokes out of primary coil when ignition key is turned on. We replaced coil with new one, but problem still exists. Can anyone please help me?
I don't think the issue is with the coil, but a wrong connection somewhere. I bought a new 12 Volt 750 deep cycle marine battery, Motor will start but coils starts to smoke alm ost immediately. I hooked a 6 Volt battery to the motor and it will crank motor and coil does not smoke, but does not have enough juice to start motor.
Should I be using a 6volt battery?
Please help me.
Thanks in advance,
Darcy
dstobert@shaw.ca
  #2
Old July 19th, 2008, 01:45 PM
jarand82's Avatar
jarand82 jarand82 is offline
Default Re: 1967 Mercury twin 350 (35hp) COIL SMOKES
Should be using a 12v battery. Does your coil smoke withe just the key on, or with just the motor running?
  #3
Old July 19th, 2008, 01:53 PM
Coil smokes as soon as the key is turned on,
Thanks for the fast response
Darcy
  #4
Old July 19th, 2008, 01:58 PM
jarand82's Avatar
U should only get power to the coil when rolling over the engine. if its smoking with just the key on than u must have a wiring problem.
  #5
Old July 19th, 2008, 02:02 PM
Do you have any suggestions on how I can or should troubleshoot this problem? I've tried removing one wire at a time to see what will happen, but it seems that every wire is where it should be, But I have been wrong before. LOL. I appreciate any suggestions or help you can offer.
Thanks again,
Darcy
  #6
Old July 21st, 2008, 02:44 AM
I figured it out. YEE HAAAAA!!!!
Turns out that the ground wire was corroded. I put a new one on and cleaned all the connections and brroooom brooom with no smoke. Thanks for all the help.
Now I just need to figure out why it won't shift into neutral and reverse. LOL
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1967 Mercury 350 Throttle Lever? dstobert Mercury & Mariner Outboards 0 July 2nd, 2008 12:46 AM
1967 Mercury 350 - Tachometer Stangman Mercury & Mariner Outboards 8 August 15th, 2007 10:05 AM
1967 Mercury 350 - Starter Removal Stangman Mercury & Mariner Outboards 3 August 14th, 2007 01:16 AM
1967 Mercury 350 parts dymo Mercury & Mariner Outboards 0 September 30th, 2002 07:04 PM
Mercury 350 35hp, locked up? or Not !! lynnyrd Mercury & Mariner Outboards 12 May 22nd, 2001 08:23 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
