rancherort
- Jun 23, 2008
- 2
2005 xpress x17, 05 yamaha 90hp. Boat was new never in water when purchased in may of 2008 motor is a slightly used 2005 that was taken in on trade by the dealer. The issue's are I'm only seeing 4600 rpm's at around 40mph with 13.25 X 17 stainless 3-blade. Also there is oil in the air intake cover for the carbs, that drips inside the cowl appears to be coming from the carb's. The engine at least in my opinion is mounted to low propshaft is 7" below the the pad I'm waiting on a 6" jack plate to correct this. My concern is with the oil in the intake cover any ideas as to the cause of this???
